Search the Community
Showing results for tags 'Fuel management sensor'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Greetings all! My 97 Legacy Brighton 2'2 wagon has 97,000 M. (arizona car) is mint! After an oil change at a local shop I went through 1/2 a tank of gas and got 60 miles, revs stayed high after easing off, felt sluggish on pick up. OBD Scanner showed no codes, but in a file circled fuel management sensor! I checked all the vacuum lines, one was a bit loose, had a mechanic check for leaks. He said fuel sensor is good.(?) He suggested it was the fuel pump……... Would a faulty fuel pump push less gas not more? Can't tell if all that gas is flowing into the sump or burning up? It's vanishing somewhere! Car starts, runs ok, but down on power still, not smoking, whines a bit, but the gas is getting sucked into the engine at a rapid rate! Grateful for any thoughts on what else I should check? Many thanks! Pethog in Toronto. 86, 90, 92 Loyale, 96 Legacy
