Had major HEAD up A## moment about a month ago, backed my Brat into our Tahoe :banghead: ...I still want to cry...
At least it was nearly bumper to bumper and not clear down the side on side, could have been much worse.
Well it busted the passenger lens completely up then cracked up the housing part with a few pieces broken completely off.
I figured all I would have to do was put the pieces back together pull a few dents then get it painted AGAIN at some point.
I did find a complete lens and housing, just don't want to give one of my arm bones up though.
Before I de-appendage myself I figured I would play Humpty Dumpty first.
Pieces went together okay, the tail, turn, flasher, backup lights don't function correctly.
I turn the flasher on and all three bulbs flash faintly, tail light does come on with lights, as well does the backup,
when I hit the turn signal they all flash faintly again.
I've tried all new bulbs, that did not really change my outcome any different then I described above.
One other thing I started seeing is the BRAIN box under the steering column is blinking its red eye when I turn the key on to the run position,
I have not noticed this action previously.
HELP!
ANY input is greatly appreciated thanks.
