Search the Community
Showing results for tags 'Iac Valve'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. Hi folks.... My 03 Outback is throwing the iac valve codes and having typical high idle, then rough idle at stop lights, etc. Took off the iac valve and cleaned it out as well as the throttle body, which I cleaned while still on the car, reaching in with a rag, as best I could. But it all back together with no improvement. So, I looked up the IAC at Advance Auto.... found it to cost $343! Then, at Rock Auto, 3 options $182, $252 and $232, So.... I googled the number on the blue sticker on my IAC..... A33-661 R02 .... and found one listed at alexnld.com for $13 .... wtf? Here's the link to the cheap one..... http://alexnld.com/product/idle-air-speed-control-valve-for-subaru-22650aa19c-a33-661-r02-iac/?gclid=CjwKEAiAj7TCBRCp2Z22ue-zrj4SJACG7SBEcBcsQu9JiwehHyavJQOITly2ihpk0zHVy04iejhutxoC1U_w_wcB So.... what's up.... will the cheap one work? I guess I could just order and see, but I thought I ask if anyone else is familiar with this issue. Thanks! Mike
  2. So the idle on my car has become very irregular, at first it just sat at about 100rpm and I tried using the idle adjustments but they had no effect And my should be right I just checked right before this started Now though all of it sudden it idles at between 6-900 rpm just constantly going up and down up and down, if I give it a little throttle it smoothes out and sounds find but will try to die unless I back off very slowly. One of my friends said to check out the idle air control valve but I can't find it, so anyone have suggestions?
