Search the Community
Showing results for tags 'Idle Issue'.
  • Search By Tags
    • idle issue ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 2 results
  1. I recently replaced an idle air control valve and the check engine light is still on and the idle is still rough. Do I need to reset the ecu? Or do I have a faulty wire? I'm a bit unsure because normally I've never had to reset the ecu.
  2. I'm having an idle issue that arises every so often seems to happen at random and can't seem to pin point what may be causing it. After intermitant driving and coming to a stop the idle pulsed between 1300rpms-1000rpms. Any ideas of where to start would be appreciated. This is my first EA and not su...
