Search the Community
Showing results for tags 'Impreza Outback'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. some background: Just bought a 98 Impreza Outback (automatic).. When I bought it the CEL was on and the previous owner said it was because the stock airbox and intake tube had been removed to put a cone filter in its place.. He included the stock airbox and intake tube with the car, so put the intake tube back on.. I was unable to put the airbox back on because the ears on the MAF sensor had been cut off to fit the cone filter onto the maf.. what the car is doing: Sometimes when I start it, it will idle at about 2000rpm and then drop to 1500rpm, and then when I put it in drive it will drop to 1000rpm and i can drive it with no major issues.. But other times it's different. When i start it it will start at 1500rpm then slowly drop to around 800rpm and start misfiring bad. When this happens it's completely undriveable. But then I can shut it off and start it back up and it will run fine again.. Occasionally, it will be running fine and then start running crappy out of nowhere.. I had the CEL scanned and it read: knock sensor, iac valve, and misfire on all cylinders.. I replaced the knock sensor today and it runs better when it runs good, but it still does the crappy misfire thing sometimes.. any ideas?
