Search the Community
Showing results for tags 'Legacy 97'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Does anyone know which wire color is which? I need to find my wiring problem. I would guess Black is power, which I believe should be 5V? Past that I am guessing. Once TPS plug is removed finding live and ground should be easy; do I need to worry about finding the signal wire (0.2V right?) (other than inspecting all the wiring for wear). If I am lucky There will be some worn insulation so the fix will be easy. Otherwise I need to find a bad ground I am guessing? Should any one have a diagnostics procedure or flow chart I would be REALLY grateful. Thanks again! Note Throttle position sensor has already been replaced, this is no longer intermittant and occors most days at start up.
