1999 Subaru Legacy 2.2L AT Wagon
2.5L block, 2.2L single port heads with correct MLS HG for block
Delta 1500 grind
KN filter on the stock cold air intake
Problem: Starts OK then stalls after 3 seconds
Recent maintenance:
New battery
Replaced plugs & wires with new NGK
New coil pack
New fuel filter
New alternator
I cleaned the MAF with MAF cleaner. Then the problem started
Car had been running good on the road; some minor stumbling between 1000-1200 rpm
Problem troubleshooting; What I've tried so far:
No CEL Disconnected MAF; would not run New MAF sensor; reset ECM by disconnecting battery for 30 minutes; no luck Disconnected MAF; would not run Disconnected battery over night; no luck Swapped out fuel pump with known good spare Visually checked for vacuum leaks; not that many hoses No CEL
Next:
IACV? ECM? 22611 AD66B DY7 80
