Search the Community
Showing results for tags 'Massive Gas Consumption'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. I started out getting 33 mpg then took it to a shop (mistake) and they replaced entire exhaust system (except for back catalytic converter), fuel pump (don't think it really needed to be replaced), transmission mounts, u-joints, and back driver's cv axle. I left the shop with a clicking sound somewhere down in front but can't tell where it is coming from. It seems to rotate with the wheels. Goes away when I put on the brakes. No rocks and it doesn't appear to be the axle. And my gas mileage has gone down to if lucky 18mpg. I've changed the EGR valve, plugs (wires were still fine), O2 sensor, thermostat, rear passenger axle, cleaned the distributor cap and cleaned the switch connected to the EGR valve. Still horrible gas mileage, running rich, black smoke and bad smell according to the guys working on it. Still throwing EGR code and they can't figure out the cause. They said if they remove half the stuff off the engine (smog related stuff), so that it passes Oregon and Washington but not California that it would get way better gas mileage and performance. Tomorrow, I plan to clean the throttle position sensor. No idea if that will help. I've got 4000 into this car that would only be worth 1700 mint. Ideas, suggestions, thoughts...?????
