Search the Community
Showing results for tags 'Mechanical Fan'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hi all! Recently my BumbleBeast developed a Weird noise, a Rattle Sound that was only noticeable at idle; So I checked it and I originally thought that it had Worn A/C Compressor's Ball Bearings... (as you can read ~► Here ) ...but the A/C kept working fine. So, I was about to install my Brand New SJR Lift kit for the front only... (as you can see ~► Here ) ...and I decided to Remove the Weberized EA82 engine from my BumbleBeast to check it carefully and make the lift install easier, also, I got Rid of the Timing Belts' Covers at all... (as you can Read ~► Here ) ...Because I thought that the Weird Noise source could be a Worn Timing Belt Tensioner's Ball Bearing. Then with the Engine out, I Discovered that the Source of the Weird noise was the Main Fan, the one attached to the Water Pump's Pulley, also known as "Mechanical" fan; so my BumbleBeast's A/C compressor is fine. A Little bit of Background History: The Fan clutch it had, failed around year 1993, so I decided to Fix the Fan by Drillin' a 1/4" Hole thru the Fan clutch and insert a 1/4" Twisted wire into that hole and Welded the wire to the Fan's Base. It worked good since then... but now, several years later; the Hole I Drilled on the Fan Clutch's area, became Wider and the Welded wire is Loose, also the Fan is Loose, so that thing is Ruined... I Need to obtain a New Fan for that, I'll Like to Keep the original fan setup, but here comes the Question: is there any Fan that fits the Pulley on my EA82 that comes without Fan Clutch? I Really need one, ASAP... Kind Regards.
