Search the Community
Showing results for tags 'OBD I'.
  • Search By Tags
    • obd i ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 1 result
  1. So I encountered a weird issue with a 93 Leg the other day. First encounter. Won't start, voltage kinda low, but engine cranks fine. (brand new battery and alt) HAs the "hollow" cranking sound of a timing belt off a few teeth. Reset belt, it was 1 tooth off, probably installed wrong, not s...
