I will likely be buying a 2008 Impreza 2.5i 5sp manual sedan from a family member. I'm looking for an extra set of used wheels for mounting dedicated winter tires. The car has OEM "10-hole" steel wheels, 16X6.5JJ:ST, 55 mm offset, 5x100.
I went to the Subaru website to see what other years and models used this wheel, part # 28111AG170. Under the "What this fits" tab, it shows this wheel was used only on the '08-'11 Impreza sedans and wagons.
Looking up steel and aluminum wheels for this car on car-part.com, they show salvage yard listings for only the '08-'11 Imprezas (consistent with the Subaru site) for the '08 Impreza.
On another thread someone commented that many year/model Subarus will accommodate the same wheels.
I know that if the steel wheels are not exactly the same, there can be a problem with the wheel covers fitting. I ran into that with the rims I bought from a junkyard for my '93. I will consider used aluminum wheels too.
Tire Rack has aftermarket steel wheels w/50mm offset vs. the OEM 55mm.
Can someone shed some light on what year/model OEM wheels are the same fit as the factory originals?
