Search the Community
Showing results for tags 'Outback transmission'.
I recently picked up a 97 Legacy GT sedan to use as my work car. I purchased the car knowing the transmission was in bad shape and would need a rebuild or replacement. I removed the transmission this week and had plans to swap in a 98 Outback transmission. I inspected the ring and pinion on both and determined the transmission in the GT which the PO advised was a low mileage JDM swap had a 4.111 ratio. The Outback transmission had the correct 4.444 ratio that should be in all of the 4eat 97-98 2.5 powered cars. I have searched the forums and not been able to find decoding information for rear axle ratios. I was only able to find a small sticker on the back of the rear differential housing with "T2" on it. does this indicate the gear ratio? If so, what is the ratio? My theory is the PO swapped out the original transmission with a transmission with the wrong ratio and damaged the transmission due to the incorrect ratio. The engine and transmission that were in the GT when I bought it were JDM swap according to the PO. He did not have the paperwork on the JDM engine or transmission. Both looked really clean, however the transmission is noisy and the PO said it slips at highway speed. The fluid smells burnt. To reiterate, I need to know how to tell the rear differential ratio so I match up the front differential correctly when I put a transmission back in. I know it should be 4.444, but since other things have been swapped and there is no paperwork for those items, I don't feel comfortable assuming it is still the original rear. I am starting to have suspicions this car may have been a 5MT car to start with. I'm guessing that information would be in the VIN somewhere. Can someone tell me where that is in the VIN?
- 8 replies
- Legacy GT
- Outback transmission
(and 2 more)
Tagged with:
I've been asked by my neighbor to replace the transmission of his daughter's 2000 outback. There is a clunking when turning to the right and the right wheel will bind in one spot when rotating it. We are in a barn and have good access from above. With the right sling and come alongs and supporting the transmission with a floor jack. I think it's possible to pull everything out from the top. Am I crazy or what?
