Search the Community
Showing results for tags 'Seat swap cloth interior'.
Hey everyone today I was able to successfully swap in 2000 Subaru Impreza RS seats into my RX. I had to custom fabricate some new mounts to get the seat to bolt. I actually used a seat belt nut to bolt in the back of the seats against the firewall. Above is a picture of the floor before I started welding up the front brackets. I made the brackets out of some extra metal I had laying around 1x1 inch square tube and 16 gauge sheet metal. Welded the nut into the backside of both pieces Then mocked up how the seat would sit and welded these up For the picture above I had to bend the bracket up so it could sit flush against the mount I welded to the floor. The back mount I just used the existing mount for the seat rail the way it was and bolted that straight down to metal box I welded up on the floor. The seats sit a little high but still very comfortable Everything is pretty straight but I am going to do some fine adjustments of everything eventually, Another view from the back below. I need to take some more pictures of the seat mounts when I am 100% finished the other side can use stock locations for mounting point just have to bend the tabs down and just screw the rear into the seat belt mount like i said previously. This is great because now I can put a bunch of different seats into this car.
- 5 replies
- 1
- Seat swap cloth interior
- Impreza rs Subaru RS Mounts
- (and 5 more)
