Search the Community
Showing results for tags 'Temperature sender'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hey all, I am trying to button up all the loose ends with my EJ22 swap. This button has to do with wiring the EA cluster to the EJ Temp Sender. I tried doing a parallel resistor. Not sure if I did it correctly. I put a 270 ohm resistor where the EA gauge cluster wire meets the EJ Temp Sender wire, then connected the resistor to ground on the body. There is no change. My gauge reads way past the "H". Does the same if there isn't a resistor. I tried putting it inline, just to see what happened. The needle then wouldn't move past the bottom line. I know that it isn't overheating. It does this after a cold night, and only turning the key to the "ON" position. Fans work correctly as well. I know I need to just do an aftermarket setup, but I'm in the midst of moving from SD to CO, and I just want a little peace-of-mind-reference for the temp.... If I were to attach the resistor to the signal wire coming off of the sender (I mean attaching it within an inch or two of the actual sender), then to a ground, will that affect the signal going to the computer? Will this mess up fuel economy? Throw a CEL? Are there any pictures of what a parallel junction looks like? I am kinda guessing. I've done a few searches (more than a few), with multiple search entry options. Not trying to take up USMB's space.... Thank you for your time, Greg
