Search the Community
Showing results for tags 'Wiper arm'.
Someone busted off the rear wiper arm of my 2005 Legacy Outback. I called Subaru parts department and got a replacement, part# 86532AG09C. After finally removing the stuck plastic on the old one, this new one won't fit. There is a metal nut with teeth on the bolt, the plastic was stuck to it when I took the old one off. When I go to put the new one on, the bolt doesn't stick out far enough to thread the nut on to hold it in place. That metal piece with teeth is in the way. I know that piece is important to catch the plastic but the new arm's plastic is too thick. I called Subaru and they confirmed that it is the correct wiper arm and I don't really want to take it in and pay someone for something so small. Any help would be greatly appreciated. It's snowing and my teenage daughter is driving the car.
Hey guys need some guidance here. I own a 99 subaru forester s and the windshield wipers don't work properly. The wipers Park to far both ways so they slam into the edge of the window on both the bottom and side. They do not do this everytime they go up and down but often. And each time they go in their rotation they stop at different points on the windshield. This also only happens when the windshield is wet. If dry the wipers stop normally maybe even a bit not far enough. The more wet the windshield is the more the wipers slap against the edges of the window. Ive already take off the panel to inspect the wiper linkage and cannot find any issues with it. The arms have no issues either and the arms lock into place when bolted on as well. What else could be the issue? Anyone else had similar issues? I'd be very appreciative if someone could share some expertise on this topic and move me in the proper direction to fixing the issue. Thanks
This is a write-up on using the Rear Wiper Arm from a '09-14 Honda Fit. This is a direct bolt on upgrade! Parts Needed: Honda Fit Wiper Arm Part Number: 76720-TF0-003 Wiper Blade: Trico Exact Fit 16B Install Duration: 5 Minutes _____________________________________________________________________________________ First off a new genuine Wiper Arm assembly can be found on Ebay for $23 or less, usually free shipping! Most don't come with a Wiper blade as shown, but most parts houses will have the Trico Exact-Fit 16B which is no longer the J-hook style clip. Now once you have the Wiper Arm, remove your original one by removing the one 10mm nut behind the plastic cover, pull off the old Wiper arm (May need to jiggle as they tend to get stuck on the motor shaft) once off, remove the round plastic dust cover which covers the motor shaft and nut, this part will no longer be needed as the new Wiper arm covers that. You will then want to position the new Wiper arm so the Wiper blade will be Level with the Window Trim/Seal, once adjusted, apply the original 10mm nut and tighten down with mild force, the Shaft will press into the Beveled washer inside the new wiper arm and it will not slip under operation! Install the new Plastic nut cover provided with the Wiper arm and you're finished! The new wiper arm will press harder on the window for a cleaner, consistent wiping path. One of the best upgrades you can do for visibly. Enjoy, -Tom Note: This setup may also work on the EA81 Wagon and Hatchback.
