Search the Community
Showing results for tags 'ac compressor'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 4 results
  1. I am putting a 2001 Legacy engine into a VW Vanagon as an engine conversion project. The van does not have AC, so I figure "why do I need to hook up the belt to the AC compressor? Is it possible to just leave it off and have that many less moving parts in my engine? What are the benefits and downsides to driving with this belt off? Thanks! Jason
  2. I own a 2006 Impreza sedan with 134k miles. When I started the car today I heard a loud squeal. I couldn't tell if it was belt, idler pulley or AC clutch bearing. I removed the idler pulley and checked it. It seems to be rolling fine and not binding. Once I put it back together the squeal was gone until I turned on the fan. When the fan was on it would squeal, when off no squeal. Anyone else experience this? Thoughts on repair. Thanks
  3. what kind of ac compressor is on a subaru gl Hitaichi or something else????????
  4. The A/C compressor on my '89 RX has started to make a groaning noise when the clutch is engaged. When the A/C is off, there is no noise. It sounds like the bearing needs lubrication. When the engine revs the groaning increases. What is the easiest way to fix this? Should I add more R12 (I don't think it was ever converted to 134 previously and I have never touched it) or is there another way to relubricate the compressor? Could it be a belt tension issue? Understandably, I would like to avoid replacing the compressor.
