Search the Community
Showing results for tags 'ac compressor repair'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. I've got a 1994 SVX used primarily by my sons. The compressor belt started squealing and the ac compressor looked to be smoking when we had a chance to stop and pop the hood on a recent trip. From what I've read, either the compressor clutch and/or the compressor itself are toast. Couple of questions: 1. There are no longer any compressors available from Subaru (they were about $570 if available) or the repair shop providers, so this narrows the replacement choices to recycled (junk yard) or re-manufactured compressors. Has anyone installed used ac compressors from recycle yards? How about re-manufactured units? My mechanic doesn't want to go the reman route as he has had bad luck with reman compressor failures and the concomitant finger pointing. 2. If I used junk yard or reman parts I may end up doing this myself. If the compressor itself failed, other parts may be needed as I've read that metal bits come out of failed compressors and clog up the downstream and possibly the upstream bits. Does this make sense? How do I check to figure out if I need to replace the condenser and the dryer and the low pressure input pipe? If it's just the clutch on the compressor and the test for a bad/clogged condenser and/or bad dryer shows no need for replacement I'm inclined to try a junk yard compressor? Any ideas on how to proceed with determining the extent of the damage and part sourcing steps? What to look for when requesting a recycled compressor? Any recommendations on used or re-manufactured sources which have been successful?
