Hey guys an introduction first. As of 3 weeks ago I'm the new owner of the Desert Fox! 1984 Subaru DL Wagon. I just replaced the throttle (accelerator) cable as it was binding up during the beginning of the pedal travel. Heres what happened afterwards.
Let sit for about 30 minutes because the engine had probably flooded from me fiddling with the throttle getting the new cable on.
Went out and started it without pumping the pedal at all. Car started but idled high, revved it up. Let it run a minute. Blipped the pedal and idle dropped down.
I shut the car off. Started it again without pumping the pedal at all and it idled high. Let it run for a minute again. Blipped the throttle and it dropped down again. I shut it off.
Pumped the pedal to the floor once, released, and started it. Idled high again. Blipped the pedal and it stayed where it was as far as idling. Let it run for a bit. Shut it down.
Got out and adjusted the nuts on the cable sheath. Thinking that might have something to do with it?
Tried to start without touching pedal. No start. Feathered the pedal as I cranked. No start. Fully depressed pedal and released. No start. Fully depressed pedal 3 times and released. No start.
Adjusted the cable sheath nuts back to where they were originally.
My normal starting process is pedal to the floor once and release and it starts right up. Even when is 20°F out its 30 today.
Same thing with the no start. I'm going to let it sit overnight and try it tomorrow unless anyone has an idea.
