Search the Community
Showing results for tags 'at temp'.
  • Search By Tags
    • at temp ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 5 results
  1. I recently bought a 1995 subaru legacy with about 180k miles on it. I knew when I bought it that it had an issue with the oil pressure guage, which I fixed. After that, it ran well for a few weeks. Then a few days ago I took it less than a mile to the store, and it drove great on the way there....
  2. I have a 1998 Subaru Legacy. Recently the AT TEMP light flashes - 16 times- on start up. I took it to a general mechanic and a transmission specialist, and there were no codes. Also when making sharp turns, especially in reverse it seems to be stuck in 4wd. I put a fuse in the FWD, but that hasn't d...
  3. Hello. Thanks in advance for reading. A bit of a long post, I'm trying to provide as many details as possible. History I recently swapped a '95 4EAT (90k) and rear differential into my '92 Legacy L AWD Sedan. The original final drive ratio was 3.90, and is now 4.11. However, the winter tires I am...
  4. I recently purchased my second Subaru, and it has some puzzling problems. When I start it up, it revs up to 1,500 - 2,000 rpm for 30 seconds and then drops down to 1,200. The AT Temp light flashes 16 times, and the Check Engine light is on. When I shift the transmission into gear and try to drive...
  5. Hello USMB users, I am asking for help diagnosing a flashing AT Temp warning light on my 1998 Legacy L 2.2. The warning light flashes only when the car is started and the turns off after a few flashes. Also when making a tight turn it seems the wheels in the front are having trouble. They tires...
