I have a 91 loyale with an A/C problem. I was charging the A/C system with R12 and when the A/C was turned on it would run for 10 seconds and then the clutch shutoff off. When I would turned the system off and back on it would work for 10 seconds and the clutch would cut out again.
Following an earlier thread I found on this forum I jumpered the belt protection system. The A/C clutch engaged and said engaged. temp out of the A/C was 57 degrees F.
My question: Is it OK to leave the system running like this?
Also is the pulser bad? Is it turning off the clutch? Is their a test for the pulser?
