Search the Community
Showing results for tags 'bi metalic'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Folks: I have a 1983 Subaru GL wagon with a 1.8 engine, and it has a Hitachi carburator that has an electrically heated, bi-metalic automatic chokeoperation. Anyway, the thing has been VERY cold natured just recently, and until it runs for several minutes, it goes like a bucking bronc. The Haynes manual book tells me to check for voltage at the electric bi-metalic heater. I did, and it only reads 1 (ONE) volt. Is this supposed to be all it reads??? That wire is supposed to send current to the bi-metalic automatic choke thus heating it up so that it expanded the bi-metalic coil, and opening the choke slowly. Although the book don't tell how many volts it;s supposed to read, there is an illustration in the book, and the electrical multimeter in the pic is reading 6 volts. I also turned the ignition to the "on" position and put my finget to the bi-metalic coil and it dod NOT get hot as it;s supposed to. Is there something like a resistive wire that is limiting the wire to the 1 volt I'm reading, therefore, not giving it enough heat to make it operate the automatic choke??? Thanks a LOT fo rANY help. Chuck
