Search the Community
Showing results for tags 'brake light'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 2 results
  1. Need help! Cant seem to find the exact same issue on here like I am having. 2002 Forester 5 speed installed new alternator checked all brakes. Battery and brake light are on and will go OFF, when I unplug the 2 wire alternator connector both of the lights will go off, while the brake light is on also it gets brighter when I actually pull the brake up so don't think it is that switch. What I have determined and tried so far: 1. Battery at rest 12.6 V and i also checked with an electronic load tester and it shows 100% charged, <4 meg ohms resistance and passed a 625CCA load test. 2. With car running battery reads 14.8 to 15V (already replaced alternator already assuming it was a bad regulator and it had 180K miles on it before doing any of this) 3. When I unplug the 2 wire connector on the alternator both lights go out and the battery goes to about 12.3V running with no accessories on. 4. I have cleaned body and motor ground connections with sandpaper and reinstalled. Cleaned and put protector on battery post. Used electrical cleaner on the 2 wire Alt connector. I don't understand the problem, is this and the other alternator possibly putting out over voltage out of cars computer accepted parameter and causing the light(s) to come on? Am I missing something? I am a master electrician (big wires LOL) and used to restore old cars and do modern engine transplants into them so not a total novice but this LITTLE problem on the Rue has me scratching my head....Any suggestions?
  2. The question says it all. I was having alternator problems, so I got a new one. It simultaneously killed my battery, so I got a new one, too. But my e-brake and battery lights are on and blink simultaneously from time to time, even going off for periods of time. I'm a complete n00b to the forum, but even though I could find people with the light problem, nobody has had the issue after just replacing the alternator and battery as far as I could tell. I have no issues starting the car, dimming lights, etc, like I did when the alternator went bad before. Any hints or tips? Thanks guys!
