Search the Community
Showing results for tags 'brake pads'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 4 results
  1. Hey! Seeking opinions, had my brakes inspected, bought car at 33000 mi. It has 112000 mi. Same brakes, no issues but figured its time so got them inspected , was told they are at 5 all around. Good reputable shop quoted me $1000.00 for replacing brake pads and rotors. Said that is for OE Ceramic pads and rotors.and said if I had it done at Subaru it would be $1900 , I'm not a cheap skate but I'm also not really rich, I know brakes are important and not the place to scrimp. Does this estimate seem expensive? Thoughts? Wondering ballpark what other members have paid? Thanks
  2. What is a good price for repairing brakes on my 1999 Subaru Outback? That's probably a silly question. It seems I may need to replace the pads on all four tires and perhaps the rotors too. Just one more thing to deal with. Any suggestions on shops in Wenatchee Washington.
  3. I'm thinking about overhauling the brakes on my 88 GL soon, any recommendations of brands for pads/shoes? I'm just running stock rotors/calipers and rear drums for now, but I'd like to make my purchase worthwhile. The wagon is mostly a daily driver. Thanks! (also, links to a thorough rear disc conversion writeup would be much appreciated!)
  4. Hey guys, i need some advice on how to handle this particular situation, as some of you know, i've been around the forums here asking for advice on various things with my 82 wagon, affectionately named Ruth. So, I'm at the point where i need to decide if it is worth taking Ruth to the mechanic to have the brakes worked on, or if working on the brakes is something that My friend and I can handle. My buddy is pretty mechanically inclined, and has done brake work on similar manual brake systems including a 1970 Camaro, and a few VW bugs. I personally have never done any sort of brake work. So here is whats wrong as far as i have deduced. Brake Pads - They are shot on front passenger side. One of them broke off completely when i was checking them out this morning. I looked and it has been pushed out of place from the last time i drove. So there is the brake pad problem. Brake Rotor - The passenger side brake rotor has a pretty deep bore into the outer most part of the rotor. 99% sure from the busted/worn out pad. So the rotor on that side needs to be replaced, i don't think it can be refinished. Calipers - They look fine on both sides, but because of the busted pad i can't really tell. I feel that i should get the calipers replaced on both sides, or at the very least the passenger side. Brake Pistons - I have not checked, but I think they are fine. Master Brake Cylinder - Almost entirely positive that there is a busted seal in there. The brakes don't leak when parked, but when the car was driving I had to really keep my eye on the fluid tank. The brake has always been a little spongy, but has always been able to brake, fairly hard on a couple of occasions. Still, There is definitely been air in the system, and i don't know if it was me, or the master cylinder was already busted before I bought Ruth. Side Note - there is wetness underneath the Master Cylinder, and i think it has dripped over to the brakes on the drivers side. I don't believe the rubber hoses are having an issue or are in need of replacement. I think the fluid is all from somewhere near or in the Master brake Cylinder. Are these all things that my friend and I, and possibly one of you awesome Forum memebers, could work out? Or should i really take this to a mechanic and have them fix it. Some quick pricing puts me at 200-300 bucks to fix it at home, 500 upwards at a mechanic. Thanks for the advice guys. I'm located in Mountlake Terrace in Washington if anyone is nearby and wants to join the fun if we make this a home project. -Scott
