Search the Community
Showing results for tags 'brake reservoir cap'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. I am a big fan of Motive's power bleeder - happily used with adapters for my GM and VW vehicles. So easy and efficient to push old fluid and air out of all four wheels quickly! But there is no cap adapter available for the 1996 (not sure what other years) Legacy brake fluid reservoir. The so-called universal adapter is a big pain. So I took a trip to the junkyard to pick up an extra 3" cap. I drilled out the center for a barb fitting and used large washers on each side to distribute the load on the silicon gaskets for the fitting. I attempted to use the original gasket for the cap. I cut out the center for the fitting. But it would not seal at all. Turns out the original gasket is meant to use the center membrane - there is a small pressure relief groove on the edge of the gasket. This prevents a true seal with the cap mod. I tried several rigged "gasket-like" setups to try to get a good seal. But it just wouldn't happen. Then I realized that the three tabs under the gasket prevented anything from seating flat. I ground these down flush with a Dremel and a craft knife. Then I placed a toilet gasket (shown in the picture) that had an excellent bevel to it. Cap seals perfectly. - and now I can power bleed my Subaru!
