Search the Community
Showing results for tags 'caliper piston'.
This is a follow up to a thread from last week about replacing a front caliper and recommendations as to used, new, brand, etc. I started out with a garage that told me my front passenger brake was sticking, the cause of our 2003 base model outback 146k miles, pulling to the right. They recommended replacing the caliper, rotor, pads at about $600. I just did a $90 alignment and $550 worth of tires so wasn't in a position to spend another $600. I asked did they check the slide pins, they said yes that's not the issue. I declined and took it home and started looking for answers. I finally after having our garage snowed in, was able to pull the wheel, and examine the caliper today. One slide pin worked fine, the lower one was frozen. It took a pliers and brute force to move. Once out, the good one was lubed, the bad one was bone dry. Next once I got the pads out I found the backs of the pads against the pistons to be very rusted and the insides of the Pistons to be full of rust or dirt or both. One had rust inside, the other looked like a pipe that corroded down to 80% of its capacity. So from here, should I clean the insides with a wire brush maybe on a dremel, or just clean away the loose debri/rust, or replace the caliper. Nowhere locally can I find a rebuild kit that includes new pistons and we have all the major chains. Subaru tells me they discontinued caliper rebuild kits. I bought a new Subaru rotor, and pad set with the hardware. If not for the rust I'd be looking at a simple clean & lube I think. I'm still pretty new to this and not sure I'd be able to rebuild the caliper, if I could find a kit. I'd like to finish this up, today Tuesday the 21st here in eastern PA because I'm working in an unheated garage and it's supposed to get cold again on Wednesday. I've got a bad back & neck, so working in the cold is not good for it. Thank you in advance for any help & advice. Spiney-Dave
- 7 replies
- 2003 outback
- front caliper
(and 3 more)
Tagged with:
