Search the Community
Showing results for tags 'case split'.
Hi all, I am about to throw my SOHC 2.5/DOHC 2.5 frankenmotor into a '98 outback in pretty great (cosmetic) condition.... but it is 200,000 miles. I have gone through about 4 different 5mts in the past 6 years... All were cheap, but all were high mileage. I'm planning on purchasing a transmission that came out of the '05 Legacy GT wagons... Transmission code: TY757VBAAB... The gear ratios look to be a dream! With my wheel/tire choice, I can be at 3000 rpm and going 75 mph down the interstate and thus keep very good fuel economy. My problem though... In the picture of the transmission that I'm looking at, there doesn't appear to be a speedo-sensor installed... There is a plug circled in orange... Anybody have a guess if there will be a speedo gear in there when I take the plug out? If not, I'm assuming that I'd have to split the case halves to install? Just a matter of spending the time to do so? Unfortunately I'm not in a position to get this information as the transmission is coming from an online auction source. Supposed to be at about 50,000 miles. I guess I could go without a speedometer, and just memorize the tachometer-to-gear-ratio-to-wheel-size speeds off of a chart... I figure it'll last much longer behind a NA motor versus turbo... http://www.rallispec.com/downloads/Transmission ID Chart_Public.pdf http://www.gearhack.com/myink/ViewPage.php?file=docs/Subaru Transmission Chart Thanks all, Greg
- 7 replies
- transmission
- speedometer
(and 5 more)
Tagged with:
