Search the Community
Showing results for tags 'catalytic converter'.
  • Search By Tags
    • catalytic converter ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 14 results
  1. Hello all, My wife drives an '05 Outback Wagon base model, 2.5 H4 non-turbo. 100,000 miles, barely broken in. Exhaust leaks started a few months ago. Brought it in to my local mechanic and I'm not sure what to do. He says the entire exhaust system is too rusty to salvage anything. So, I'm...
  2. Hello all, My '05 Outback 2.5 5 speed needs a complete exhaust system, including the catalytic converter. Not sure what to do. Would like to spend $2k-$3k. Can anyone suggest a junkyard to get a used cat? Can anyone suggest a decent aftermarket exhaust system? I want to gi...
  3. Mom's 2002 Outback keeps throwing the code p0420. I'm told this means "catalytic converter". History (within the last six months): 2002 Outback, odometer 165,000, purchased from used Subaru sales/repair business. - Engine bearing went out. Highway breakdown within 1000 miles of purchase....
  4. Hello, So my Legacy is starting to pull a 0420 code, due to the previous owner doing improper repairs or lack of work, thus causing damage to the cat. Has anyone ever seen this modeled installed or any feedback good or bad. https://www.magnaflow.com/products?partNumber=52305
  5. Hello everyone, my 1995 Legacy Outback (340K miles now ) has thrown the dreaded PO420 code, I noticed that Subaru has discontinued OEM catalytic converters. Is there a replacement OEM part # or will I need to go aftermarket? If I need to go aftermarket, what is a quality company to purchase replace...
  6. I've got a 1999 Subaru Forester with bad catalytic converters(according to CEL scan and my mechanic). The last time i had some exhaust work done for exhaust leakage a muffler shop cut one of the pipe-to-cat.convert rusted flanges and welded. My mechanic can't weld so i go to muffler shop. They wan...
  7. Need some advice, I have a Subaru Outback 2000 with over 250,xxx Miles. Codes: P0420 and P0303 When I initially ran the reader it said the O2 sensors were bad, both front and back. I replaced those hoping it would eliminate the 420 code also but it has not. Though, the O2 sensor codes did go a...
  8. BLUF: Could failing/poorly functioning catalytic converter be related to/caused by previous gasket head cracks or by repair work done to replace cracked gasket head?? Mechanically challenged 08 Forester owner here. A few months ago, we found out that the gasket head was cracked. Right after we p...
  9. 98 OBW w/ 2.2 240K miles The back story. Three years and 5K miles ago I performed significant exhaust repair. I replaced the rear catalytic converter, O2 sensor, center pipe and muffler all due to rust. I purchased the parts off the internet. All of them were aftermarket. I could not get t...
  10. I have a 2003 Subaru Impreza Outback Sport with 73,xxx on it. Recently, it has started to hesitate badly while accelerating and will not go faster than 50 mph. I took it to the local dealer, who wants to charge $2,300 to replace the catalytic converter and front o2 sensor, saying it was plugged...
  11. I snapped off the threaded collar on the catalytic converter for the front oxygen sensor and am now trying to replace the whole catalytic converter from flange to flange. How do you get the top bolt off of the front flange between the cat and the header pipe?
  12. Hi Everyone!! I'm in need of some help. I live in California and I bought a 07 Impreza 2.5i (non turbo) about 2 years ago. After my first smog check the car's check engine and cruise control light came on. The cars performance has not changed or the gas mileage so I didn't pay attention to it. N...
  13. Hi, I am new to this forum. I was hoping to get some advice on my new outback. Its a limited 5spd with 141k miles. the check engine light has come on and gone off a few times since i bought it, but now its been on for a while. i borrowed a code reader and it came up with the all too common p0420 cod...
  14. Help, when I have the heat on in my car, and I come to a stop, the car smells like burnt oil in the cabin. A friend told me it might be the head gasket as subarus have this problem... 130k automatic turbo... ANY THOUGHTS OR EXPERIENCES RELATED TO THIS WOULD BE APPRECIATED!
