Search the Community
Showing results for tags 'center differential'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 4 results
  1. Attached is my write up I created after replacing the Viscous Coupler in my 1999 Impreza OBS, 2.2L, 5MT, Phase 2 car. I only had Word to use, so there is more pages than I wanted. Apparently after 10 years the program has changed a little bit... Feel free to ask questions about anything. Subaru VC.pdf
  2. Not sure if this is already posted here somewhere, and, perhaps a mod would like to move it but, user plainom at subaruoutback.org has a slideshow of the center viscous LSD in a 5spd. if you need a password; centredifferential http://s1008.photobucket.com/user/plainom2/slideshow/MT CENTER DIFF PRESENTATION more info about this here; http://www.subaruoutback.org/forums/66-problems-maintenance/216090-manual-tranny-center-differential-dissassembly-incl-viscous-coupler-slideshow.html
  3. Can the cable TO brg fork be used in this later hydra clutch trans? Has anyone here done the ej R&P swap to a EA d/r trans using the late 99 up 8 bolt bell housing 5 mt trans? Replacing the d/r 3.90 R&P with a 4.11 R&P from a 99 Lego OB & adding the viscous center diff for AWD. Here are links to similar threads about this; http://www.ultimatesubaru.org/forum/topic/129898-4444-x-1592-x-3545-251/?hl=transmission http://www.offroadingsubarus.com/outbacklowrange_part1.html Thanks!
  4. I know this has been discussed but right now I am searched out and confused. I have spent quite abit of time on the older side of this sight but my wife's forester is acting up. Right now I have the fwd fuse in place and the torque bind is still there. I wasn't sure of alot of things in the threads already posted. Is there a difference between Automatic and Manual tranfer duty systems? Is the clutch assemble filled seperate from the main transmission? What oils do I use? When and where do I ad a friction modiffier as suggested? There seems to be a wide variety of opinions on this. Thanks in advance. Cheers!
