Search the Community
Showing results for tags 'center lamp'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 3 results
  1. Attaching 2 wiring documents (PDFs) from the old Ultimate Subaru site so they don't get lost. Original Authors are: Wagon78 Chris Lantieri Using Center Light Wout Relay.pdf Wiring Instructions for DPDT relay for center lamp.pdf
  2. Hi all. I am looking to setup a 3rd eye light with a DPDT relay setup. This will be in an '81 model year, EA81 wagon. So positve switched system with glass fusebox. (EJ swapped w/internal regulator ALT.........but that doesn't/shouldn't affect the lighting setup) There was a writeup in the old USRM on the indysworld server......but sadly the link is now 404. So i am looking for info on this. Where is the factory timer box located? Anybody got specs on this? I've got an 82 model Serivce Training Update that has a basic diagrahm of the Lighting w/ third eye......But it is showing the Ground switched setup of later model type......with the 3rd eye as an auxillary Hi beam, rather than a "passing" light which can be turned on anytime. And it has no wire colors, or locations of connector pinouts. This is useful.....and I can post a scan of it for others.....But I really need to find good info on the early setup, where the timer is, and how to bypass/replace the original with a DPDT switch or relay.... I will make this a Write-up with info and diagrahms thorough. If I can get it all compliled and figured out on the test rig.
  3. so ive been chasing my tail on this brat ive been working on. it has no turn signals, high beams, or hazards. intermittently the hazards will flash out of nowhere, even with the ignition off, and the key out of the ignition. the indicator for the high beams lights up on the dash, but the headlights don't work, the low beams do however, I can also hear a relay click when I turn on the switch for the high beams. there are no turn signals at all. there is a silver either relay or flasher on the drivers side behind the dash that gets extremely hot, does not click or anything. and it looks like theres a spot for another, but there is nothing plugged into it. also, I am having a bear of a time finding a Cyclops switch. PLEASE HELP!!!!
