Search the Community
Showing results for tags 'center light'.
Anybody have any experience converting the EA81 Quad Headlight setup over to the EA81 Single Headlights with Cyclops? Or know of a writeup? Believe that I have everything needed: Single Headlight Core Support Single Headlight Buckets/Bulbs Single Headlight Bezels with Turn Signals and Pigtails Third Eye (Cyclops) Full Assembly with Pigtail Third Eye Grill Relays that sit on the passenger side (RH) strut tower Third Eye Switch from factory that's used with the HighBeams on. Part that's confusing me is how the wiring goes from twin lights, one for low and one for high beam, to single units that do both functions. Guessing that the turn signal wiring that goes to the front bumper will have to be rerouted so they will go to the corner flashers of the Single Headlight Style. And then there is adding the Third Eye to the equation... The easiest method in my head; Take the entire front harness from an '82. Place that harness in the body of the '86. (thats the year of the EA81 chassis its going into.) Not sure if the connectors between those years are the same or if they were changed? I have an '82 that is badly rusted and is more like a donor vehicle. Ideally would take the cyclops light setup from it and put it on the '86 which is still structurally sound.
...before it happened. Or at least it should have. Hindsight is 20/20. The 3rd eye harness is very close to the battery. Rats were hungry and ate some of the insulation off of the red and black wires in the harness. Went to pull the battery to use in a different car; took off the negative terminal first, and then wrecklessly set it down in front of the battery, with the positive terminal still connected. Before I could undo the positive terminal I heard a "snick" similar to a fuse popping. The negative terminal had brushed those exposed wires... either the red, or black, or both. Now the highbeams work, as well as the "beam" icon on the dash. But once the 3rd eye button is pressed, neither it or the "center light" icon on the dash work. The 3rd eye was funtional before, door and light. McBrat, the one who built the straight-axle '82 Brat, had a diagram on "Indys World . com" but unfortunately that site is no longer up. What kind of tests can I do? Did I blow a relay or worse the 3rd eye?
