Search the Community
Showing results for tags 'clutch pack'.
  • Search By Tags
    • clutch pack ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 6 results
  1. Hey everyone, just bought my first Subaru. Didnt really know a lot about them before i bought it. Found out a couple days after i bought it that the FWD fuse was in so i took it out after seeing it in a hanyes manual, immeddiately noticed torque bind/shuddering at low speed turns. Me not knowing al...
  2. Hey there, I've been visiting for a while to read the threads for advice with my car but just signed up to actually join the conversation. Thanks to all the folks with the experience on here that post on these threads--I cant tell you how many times one of your threads has led me to figure out what...
  3. Hello. I have a 98 OBW. I am rebuilding the tail housing of my AT transmission. I installed the new clutch pack and now the snap ring will not fit back in place. With the rings back to OEM thickness I cant seem to get the snap ring to fit into the groove. Anyone have any tips? I used part # 315...
  4. ​Hello, I have a 98 OBW 200+. Bad torque bind, AT light flashing. I opened the tail end of the transmission and things just dropped out. Does anyone have any idea what that broken metal band is to? Also the end of this gear looks sheered off. How bad is this?
  5. I have had some experience repairing various fails of the duty c system. recently I had a solenoid fail mechanically bleeding off atf failing to lock the clutch packs yet the solenoid ohm tested fine and did not throw a tcu code. this all resulted in front wheel drive only this video depicts how...
  6. Hi all so I have had some headaches with this and never found a decisive video on how to test the rear lockup system I recently had no rear wheel lock up but no TCU code either so this is what I found and how to test the system for functionality before reinstalling into the car. https://w...
