Search the Community
Showing results for tags 'cold air'.
Hi all, '98 OBW, 2.5L high compression build, 5MT After moving to Las Vegas, Nevada about two years ago, I've finally begun wanting to use my air conditioning system. Before moving down here, I had a mechanic pull vacuum on the system and charge it. I think he put in less than 2 lbs? It was a very minimal amount. Here are the symptoms that I'm experiencing. Blows cold while driving, and cool while idling. While driving, when the A/C compressor kicks on, there is a VERY noticeable decrease in performance... almost like I've instantaneously been loaded with a 700 lb 4x8 U-Haul trailer...It'll buck/shake the car slightly. I know I've read multiple times on the forum that the A/C can rob power, but this seems exceptional. The motor has good compression (in the 200s) and has lots of power when not using A/C. I am in the habit of turning the A/C off when accelerating from stops. With this amount of strain placed on the motor though, why doesn't it just stall out when idling? The motor doesn't stumble or strain when cycling the A/C on/off while idling. What's the deal? I've checked the gap on the clutch, and it seems to be within specifications. It also appears that this clutch isn't replaceable? I've looked at the different write-ups on this forum, and the videos available, but NONE of them show the type of compressor that mine has... The Triangle with the 3 circular pieces and the single bolt in the center... I've attached the pressure gauge from one of those auto-store recharge kits, and supposedly the system is topped-off. Does this have anything to do with my neutral switch? I've checked my Short Term/Long term fuel trims while idling and I think I don't have a vacuum leak, as they're in the negatives. I'm just worried that I'm going to jump timing because of the instantaneous loading that is presenting, or the A/C is going to catabolize itself while driving and having to replace EVERY part of the system. Thanks for your time, Greg
- 26 replies
Many lunch breaks later, it sits .625 taller than stock
