Search the Community
Showing results for tags 'collant sensor'.
So I have had a recurring problem with my 1990 loyale not wanting to start. It was intermittent but got worse as time went on. Symptom: When car was hot or from a cold start, when I turned the key I would hear a clicking sound coming from the engine compartment. I would turn the key over and over again until it would finally turn over (sometimes it would take 50 times!). Car would run fine after starting. Attempts to Fix: Replaced coolant temperature sensor: A lot of posts on these causing hot starting issues. Did not fix the problem. Replaced starter: nope. Cleaned all battery connections and connections to starter: didn't fix problem Changed out battery and replaced with new one: still had same issues Actual Fix: After reading up on the USMB forums and on other toyota forums I discovered that the early Subarus do not have starter relays. As the wiring gets older and more worn out, the power going to the starter diminishes. The fix is to put a relay in between the starter and the ignition. Some people recommend buying a cheap headlight relay and wiring it in yourself. You can look up starter relay or ignition relay yourself to find instructions. Not being a mechanic myself, I chose this kit: Bosch WR1 Starter Relay Kit http://www.amazon.com/Bosch-WR1-Starter-Relay/dp/B001COAX78 The kit comes with a relay, all the wires, and easy to follow instructions including a wiring diagram. It took me 20 minutes to wire up and made the whole process a breeze. Mystery Solved! Starts up without hesitation. For $25.00 this was a cheap and painless fix (once I figured out the actual problem) Hope this helps some of my fellow vintage sub owners. Peace!
- 7 replies
- 3
- ignition starting not loyale
- collant sensor
(and 4 more)
Tagged with:
