Search the Community
Showing results for tags 'control arm'.
Hello all. 98 OBW 250K 2.2. Noticed the Front driver control arm rear bushing is leaking. I can buy the bushing for $23. Looks easy enough to swap. After 20 years on the salt filled roads of PA should I expect it to be rust welded in place and should I just replace the control arm? Can it real...
- 5 replies
- control arm
- bushing
(and 3 more)
Tagged with:
I may or may not have been drifting around in some snow when I hit a curb inevitably screwing the control arm and leading rod. Ofcourse with my luck 89' GL control arms are a discontinued part. If anyone has a parts GL or any car that has a control arm compatible with mine and is willing to sell it...
I am looking for new bushings for my lower control arm in a 92 Loyale. Lordco and Napa have nothing. Any ideas where to find some? Thanks. Located in Golden, BC
- 13 replies
- control arm
- control arm bushing
(and 3 more)
Tagged with:
Hello all, I have an '01 Legacy L 5-speed sedan, 93,000 miles, runs like a champ. Started getting bad noises from the front end passenger side every time I touched the brakes. Jacked the car up and took off the wheel: YIKES! The lower a-arm/control arm was completely rusted through right nea...
- 5 replies
- suspension
- legacy
(and 2 more)
Tagged with:
Hi folks, I just took my 1980 Brat in for a safety inspection (part of the process of importing it into Canada). I was told that my front passenger control arm is shot and needs to be replaced. I'm hoping for a second opinion as my understanding is that I just needed to replace the inner tie rod....
Im working on replacing the bushings on my 05 Outback. At first I had trouble removing the control arm from the ball joint (tried both removing the bolt from the pinch knuckle then a beating to the control arm and removing the cotter pin and trying the same beating with a hammer) but I had no luck....
- 3 replies
- bushings
- control arm
(and 1 more)
Tagged with:
