Search the Community
Showing results for tags 'control valve'.
Hi Subi Fans, I have a 2005 Outback, 3.0R VDC 5AT w sport shift. Recently the CEL came on and produced code P0768, which has to do with the Shift Solenoid 'D' electrical. The solenoid is located on the control valve assembly, which is inside the transmission pan. The problem is intermittent, and I have been able to reset the code several times, but within a few miles the CEL comes on again. This last time while pulling a steady hill as it went to shift between 3 and 4. Until my next reset, it is stuck now in one of those gears. The sport shift would not work either. Of course, about half the lights on the dashboard are going wild, and cruise control is dead. After much investigation I am pretty sure no one is re-manufacturing or rebuilding these valve bodies, and no solenoids can be purchased separately. 1) Does anybody know where I can get a rebuilt valve body with tested solenoids? I have found a used transmission (131,000 miles) for $485, which includes shipping. 2) Is it a good idea to purchase a used transmission and then remove and reuse the valve body from it? Subaru still sells the valve body under part #31705AA4309L, and those run $750 to $935. It is a new part and has at least some warranty. This valve body fits a good number of 6 cylinder 5AT Subi models from 2005 to 2007. 3) Is my best bet going to be a new valve body? Last question. It is kind of a messy PITA job to get inside the tranny case just to look at the wiring and make sure things are plugged in, and replacing all the tranny fluid is not cheap. If I am opening it up I want to replace the valve body (or the D solenoid). 4) After replacement, does the car's computer need to be reset? Or can I just drive away? 5) If so, is that something I can do, or must the dealer (or my good independent garage) do it? If anyone can help, or has any resources, please let me know - I am OPEN TO IDEAS. The car is great otherwise, but has a salvage title and 208K, so we are getting leery of big expenditures to keep it going. I have had it for eight years. THANKS !!! Craig
- 11 replies
- p0768
- valve body
(and 4 more)
Tagged with:
