Search the Community
Showing results for tags 'coolant loss'.
My 2009 Impreza Outback sport has been experiencing some persistent coolant leaks. I am quite new to working on cars so I have come to you all for help! Initially I thought that it was coming from the coolant hoses connected to the throttle body, so I replaced them, replaced the throttle body gasket...
- 1 reply
- coolant loss
- coolant leak
(and 5 more)
Tagged with:
Today I discovered very, very low oil and coolant levels in the Forester, and at 200000 KM I am hoping for good luck and a simple gasket change. As far as I can tell there is a delicate oily rainbow on the surface of the coolant in the radiator (difficult to tell with fresh pink coolant and brand ne...
- 10 replies
92 Loyale with 187K. 2WD. Is there a way to guess if this is just a blown Head Gasket or a cracked head? The car has been losing coolant for a couple of years. Now the temperature started rising. I introduced compressed air in all the cylinders at TDC. At the cylinder #2 the coolant starte...
- 23 replies
