Search the Community
Showing results for tags 'coolant temp'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 3 results
  1. My 89 Turbo Wagon and I've been experiencing some jumpy idle at start, and then the check engine light has come on. The light dissappears after the car is shut off. I checked and it's a Code 21. So I bought a coolant temp sensor and am wondering if anyone has any experience installing one of these. Thanks y'all!
  2. My Dash Thermostat is reporting as high as the needle can possibly go, it gets there before the computer reads running temp (190-200). My ODBII is reporting running temp after a proper warm up time. The sensor is a 3 wire, combined sensor/switch. Why would one read impossibly high, and the other work in parameter. I've replaced the sender. All this is after a rebuild so ground? or other ideas please....
  3. HERE IS WHAT HAPPENED. Yesterday, I discovered the green connector for CEL testing has been plugged in forever. i unplugged it, and proceeded to do what I know, in order to read the check engine light. The oxygen monitor showed codes 21(coolant temp sensor), 24(idle air control valve or circuit) and 34(EGR solenoid or circuit). It got dark, so I went inside and proceeded to look online for a replacement IACV gasket, so I can clean it. I also looked at an EGR solenoid and planned on cleaning the EGR today. When I went to start my car this morning, it fired but died immediately, and I knew something was wrong. One more start and die, and without pumping the throttle or having it wide open, the car just cranked and didnt fire. What the heck? So I read the codes again, and nothing had changed. As far as I know the only thing I did was make a red light blink, so i'm a little confused. Is it possible that the car is acting up because the ECU "didnt know" about the bad egr and iacv until i put it in test mode? before having gone inside last night i started the car, and it RAN FINE. Again, what the heck? Does anyone have any ideas? car has always had idle issues, and at one point an ignition coil that arced to the negative ground. ask me questions and i will answer, but so far, thats what i got. Thank you guys in advance. -walker
