Search the Community
Showing results for tags 'crank no start'.
Hello, I'm already working on an odd noise coming from the driver's wheel well but new surprise! The car is a 2010 Outback that we bought used a little over a year ago. 132,000/212,000km on it. Timing belt replaced at 100,000km (potentially miles though as the car is American). The valve cover gasket, spark plug tube seals, and spark plugs were replaced this past fall/winter. I did the passengar side but ended up having to take it to the mechanic for the drivers side. I'm assuming they did a decent job. I didn't replace the spark plug wires as I had planned on since the coil is on the wire making them crazy expensive. No starting/running issues since or before. I do have a trickle charger on the battery for the winter (1.5 amp) but it hasn't been plugged in for several weeks. The battery itself is pretty powerful, 1000 CA if I remember correctly. This has happened twice in the last week. The car starts fine from cold, drive it a short distance of maybe 5-10 minutes, go a short errand and car cranks but no start. The first time it happened I thought weird but it started on the second go a couple minutes later. No CEL but I didn't check with my code reader. Today it left my wife and son stranded at the daycare. They ended up catching a ride as it wouldn't start at all. I'll be walking/biking to pick it up in a little bit. I have been Googling and searching this forum. There seems to be a variety of potential causes ('*' ones seem most probably): Battery Coil/Spark Plug Wires Loose Battery Wires/Corroded Terminals Spark Plugs Fuel Filter Ignition Module* Fuse* ECT sensor* Crank Position Sensor* Cam Position Sensor ECU Fuel Pump Coolant Temp Sensor As I haven't been to pick it up I can't say about the really easy things to check but I was wondering if anyone knows of issues specific to the 2010 or that generation of Subarus that might explain what's happening? As it's only been twice I can't really narrow anything down but as it left the wife and kid stranded I'm a bit nervous. Edit: Just thought of this. We rarely drive far but over the past week we put about 2,000km on the car with two trips. If that makes a difference. Thanks in advance!
- 18 replies
Hello new friends, I have recently purchased a 1992 Subaru Loyale 1.8L on-demand AWD 5 speed with 143k from a friend. It is not in running condition and when it died it just stopped with no sign or reason. Before I purchased it they tried replacing the following Spark plugs Wires Distributor Button Cap Coil The car stopped running back in November 2012 and hasn't started since. I've spent 3 hours on this already and am ready to be done. I've double checked the timing of cylinder #1 and the distributor. They are in time and I get a strong spark to cylinder #1 and #3 however, I get a very weak signal to the other side #2 and #4. I'm confused by this, I even replaced the CAP again and same thing. I haven't tested compression yet, but I was able to see the intake valves on #1 while turning the motor for TDC (via TDC whistle indicator). and I haven't tested for proper fuel pressure, however we get a nice steady flow. The motor does not sound like it has loss of compression, but doesn't sound 100% when cranking. \ I assumed that it was flooded so it has been aired out. I will test for compression and injector pulse tomorrow. Could it be possible that if the #2 and #4 timing belt is broken that it would give a weak spark? I haven't pulled the covers yet, because it is a little intensive to pull those things. lol. The car is still at my friends Apartment so this is all being done onsite, not in a garage. Any info would be great. This is my first boxer motor and I'm very excited about the Journey we will have together. again thank you new friends -mike
- 11 replies
