Search the Community
Showing results for tags 'crank pulley'.
  • Search By Tags
    • crank pulley ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 3 results
  1. Engine type EJ251AXBWL in a 2002 Outback, the AC belt jumped and was wound up behind the timing belt cover and the crank pulley. Part of the timing belt cover was melted by the crank pulley which was rubbing on the timing belt cover. I removed the crank pulley and the timing belt cover. The timing b...
  2. Hi Everyone, Thanks first of all to everyone since I have read numerous threads to get as far as I am with my crankshaft pulley repair. The pulley had a significant wobble and the fan belt kept working its way off the PS pulley even though it was tight when I initially installed, reinstalled, n...
  3. Howdy folks, Newbie here. I need to inspect my timing belt---suspected jumped a tooth... see earlier posts by me in the last couple of days if you're interested in the full saga. I removed radiator, accessory belts already. Last step before removing timing belt cover is the crankshaft pulley...
