Search the Community
Showing results for tags 'crankshaft position sensor'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hello, I have a 1992 Legacy Wagon, EJ22, AWD. A few days ago the motor would not fire up and has not fired up since. The wagon has not had any motor work done to it for over 3 years. It ran and drove great over these past 3 years. The wagon has never been in an accident. The timming belt was replaced 3 years ago. What I've checked: -Fuses (both under the hood and Under the dash) -Ran the codes (24, 11, 13) -Inspected crankshaft position sensor. Tested sensor and found it to be working and within spec. -Inspected camshaft position sensor. Tested sensor and found it to be working and within spec. -Swapped out both sensors with known working ones just to be sure - no change in problem. ALSO did this test - disconnected crank sensor, connected cam sensor, sprayed fuel into intake, turned over motor, no run - disconnected cam sensor, connected crank sensor, sprayed fuel, turned over motor, no run. - connected both sensors, sprayed fuel, turned motor over - runs like a frickin champ. *** Cant test the Air Control Valve (code 24) because the Haynes manual does not have that part listed in the book. -Inspected Coil, All plugs are getting spark and sparking properly when the motor is turned over. -Inspected Fuel Filter. Good volume of fuel flows through filter. -Fuel Pump. I did not have the proper gauge to test fuel pressure, so I replaced the fuel pump with a brand new pump. Fuel filter sock is new to. -Tested fuel injectors, all 4 have proper ohm reading. What I've discovered is the fuel injectors are not pulsing. -I tested each electrical lead and found that there is no power getting to any of the injectors. When I switch the key on, I should have 12V. I dont know what else to look at. Any suggestions? Thanks.
