Search the Community
Showing results for tags 'dead battery'.
  • Search By Tags
    • dead battery ×
  • Search By Author
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Found 6 results
  1. Help my battery keeps going dead Just bought a 1999 Legacy and having a few problems. One is I keep loosing charge to my battery. I have purchased and installed a new battery and this did not help.(New battery still goes dead) My alternator is charging around 14V so I am currently looking f...
  2. Hello, USMB. I found you because of this incredible day we've had. It's *hilarious*, so I thought I'd share. It's the last weak of a month of 60 mandatory hours. I am commuting from the country. Get up this morning, it's 3 degrees, battery's dead because the door didn't close. OK... lucky...
  3. Not sure what, but something is draining my battery. Background- Battery died. Very low voltage. No Charging. Decided to get new alt. Swapped in a 90amp maxima alt with this style (no connector plug.) Photo from this thead. http://www.ultimatesubaru.org/forum/topic/97208-bolt-in-ea-seri...
  4. So, I've got a 97 Legacy Outback... Fuel pump went out far from home was quoted an astronomical price to fix it, called my mechanic back home can do it for $300 cheaper, so I push it onto a uhaul auto transporter and drag it home. when I get to the shop well after closing time I left the key in the...
  5. I inadvertently left the ignition on while cleaning the car, and after 18 hours it was seriously dead. Got it started with a jump (yes red to red, black to black) which did take some cranking and fussing. Since then it is hard to start, idling way low (loping between almost zero and 250 rpm), st...
  6. I inadvertently left the ignition on while cleaning the car, and after 18 hours it was seriously dead. Got it started with a jump (yes red to red, black to black) which did take some cranking and fussing. Since then it is hard to start, idling way low (loping between almost zero and 250 rpm), st...
