Search the Community
Showing results for tags 'drain plug'.
Hello, Would you happen to know where I can find the right crush washer for the CVT drain and filer plugs? I recently replaced the CVT fluid on my 2012 Subaru Legacy 2.5i and was forced to use the same washer because I wasn't able to find it, even the Subaru dealer was unable to help me since they claim that fluid is not supposed to be changed. Thank you.
- 1 reply
- drain plug
- CVT
(and 2 more)
Tagged with:
So after a long day at school on tuesday, i came out to my car after an hour or so of being home, to find a huge puddle of oil under my car. Puddle is an understatement.. it was ALL of the engines oil... Nooo! I grabed my head lamp and got under there thinking the worst. What i found was odd. The normal drain plug (the 17mm at an angle twards the passenger side) was dry as a bone, however, there was a second hole just beyond it, where all the oil had poured out along with the remains of what appeared to be a rubber grommet dangling from the hole. What is this hole? Its just behind the "normal" drain plug and is pointing straight down. what was supposed to be there? Ive worked on these alot and have even replaced oil pans and oil pan gaskets and i have never noticed this second hole before. Anybody know what this is or how i should plug it? Beleive it or not the cork gasket dosent leak and i dont want to replace the pan and go through that whole ordeal if i dont have to. Thanks for taking the time to read and your potential response. I did alot of searching and found no mention of this "second" hole or whatever it is. -1989 NA / EA82 5MT 4wd wagon Thanks!
- 28 replies
- oil pan
- drain plug
(and 1 more)
Tagged with:
