I am getting vibration while driving. My Haynes guide states that having vibration and noise that changes pitch consistent with speed is indicative of a bad rear drive-shaft. The Haynes guide seems to indicate that the center bearing on the drive-shaft can be replaced, but other sources dispute that.The car has only about 95k on it. Another Subaru Outback forum says to get a used drive-shaft rather than buying a new one (minimum I've seen for new is about $338).
So looking for some advice if I can replace the center bearing or not, or if a used drive-shaft assembly would be OK. My understanding is this issue is rare. What range of Outback years does a 2008 drive shaft fit? Any other advice on this issue would be welcome.
Thanks
