Search the Community
Showing results for tags 'drum removal'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. Hello all, Newbie here on the forums and I apologize if this thread exists - please direct me to there if this is the case! I am trying to replace the rear wheel bearing, driver's side. I followed the tutorial of a similar job elsewhere on this forum, and have removed the suspension arm from the car including the spindle with the drum on it and everything inside of it. I can't get the drum off! I have tried many tactics - pounding, flame, penetrating fluid. I also tried to find a star bolt to turn with a flathead (via the backing plate through the plug) to compress the shoes because it seems like the shoes are holding the drum on at this point, but I can't find any indication of a star bolt - does this even exist on these models? Haynes manual shows nothing of this sort... I also think the drum may be seized on the spindle. I've read that using a puller will help...but I'm hoping to compress the shoes if possible just so I'm sure to not damage those as that would add work to an already painstaking job of even trying to access the bearing (also I don't own a puller and would rather not shell out the 80+ dollars to buy one). Thanks!
