Search the Community
Showing results for tags 'dump truck'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. For the last 6 months I have been trying to get this vehicle running i have tried everything and running out of ideas.... and money. The vehicle is a 5 speed manual 1990 Subaru Loyale with an ej22 swapped into it out of a 5 speed manual 1992 Subaru Legacy. 4 out of 5 days of the week it drives normally but runs rich (I get about 16 mpg), sometimes it will surge idle/stall(also did this in the legacy), throttle wont responds unless pumped, will sometimes high idle like its cold even if it isn’t, Will have extreme hesitation/sputtering. I have replaced; Throttle position sensor Oxygen sensor Coolant temp sensor Spark plugs and wires-all spark plugs are dark black but dry. I just checked them today. Coil pack Cleaned idle air control valve Had fuel injectors rebuilt New alternator New timing belt and water pump New intake manifold gaskets Valve cover gaskets Fuel filter Swapped out computer for a different one Checked for vacuum leaks couldn’t find any Had electrical expert/ Subaru mechanic check that all the electrical was functioning properly Checked compression- all 4 cylinders were at 180 PSI- also checked today Cleaned the MAF sensor The exhaust sometimes is black sometimes is blue but is almost always white, even when warm. The catalytic converter has been gutted out Check engine light codes read 31 and 33 which is throttle position sensor and vehicle speed sensor. When I put in the new throttle position sensor today it ran much worse than usual to the point of not being able to drive. - Any help would be great
