Search the Community
Showing results for tags 'duty c'.
Hey everyone, just bought my first Subaru. Didnt really know a lot about them before i bought it. Found out a couple days after i bought it that the FWD fuse was in so i took it out after seeing it in a hanyes manual, immeddiately noticed torque bind/shuddering at low speed turns. Me not knowing al...
- 18 replies
- 1
- Duty C
- clutch pack
(and 1 more)
Tagged with:
I bought a 97 legacy L, 2.2, auto, 270k. Motor runs , trans has torque bind. Tcu codes show duty c solenoid. I wanted to drive it to see if it was worth fixing the solenoid so I disconnected the rear driveshaft. Torque bind went away but the u-joint is clunking against the differential flange. Is...
Hey there, I've been visiting for a while to read the threads for advice with my car but just signed up to actually join the conversation. Thanks to all the folks with the experience on here that post on these threads--I cant tell you how many times one of your threads has led me to figure out what...
- 10 replies
- torque bind
- transmission
(and 3 more)
Tagged with:
So, I'm just gonna post what I've got going on and what I've found and hopefully people can chime in who know more about this than me. Even if you don't know about all parts of my question please post what parts you do know. I've read alot of posts on this forum and other Subaru forums but this is...
I have had some experience repairing various fails of the duty c system. recently I had a solenoid fail mechanically bleeding off atf failing to lock the clutch packs yet the solenoid ohm tested fine and did not throw a tcu code. this all resulted in front wheel drive only this video depicts how...
- 4eat
- auto trans
(and 5 more)
Tagged with:
i have purchased a used matching transmission for my 96 legacy because after driving it around with torque bind something in the transmission gave out. (i suspect it is the front diff, between the engine block and the transmission its self) My question is, is how can i check the resistance of the so...
I am hoping, beyond what I can search here, someone has or has seen a good scope trace of the Duty C signal. In a perfect world, there would be a trace from an '00-'03 and one from an '04, when apparently the signal polarity was changed. Before '04, +12V to the duty C disabled the AWD, '04 and ab...
- 23 replies
- 4EAT
- transmission
(and 2 more)
Tagged with:
