Search the Community
Showing results for tags 'ea-81'.
Working on a clean 83 GL garage find! Been sitting for about 7years but everything on it is in great condition. Super excited about this project but am in the learning stages of working on carburetors. I’ve cleaned the tank, replaced fuel lines, filters, even traded out the fuel pump bc I was suspic...
- 12 replies
- ea-81
- carter-weber
(and 2 more)
Tagged with:
Hello all, This is my first post here, but the USMB has already been a huge help for me with my recently-purchased 1984 GL 4x4 wagon. My question, which I have yet to find an answer for, is this: where can I get a cone washer for a 1984 GL? I've had no trouble finding them online for an '8...
- 4 replies
- cone washer
- ea-81
(and 1 more)
Tagged with:
I am wondering if you can replace the EA-81 fuel injected heads with Carburated heads?
Two more questions. Can I put a Carb intake manifold on a Fuel injected engine, (EA-81), and leave the injectors in the head just to block the injector holes? And does any one have a Carb intake manifold for sale? Thanks, Wain
Hi Community, I don't know what to do, I've got an 81 BRAT, went from a Weber back to stock carb. Everything is set up as it should (according to my mechanic in Berkeley CA) and it's not coming close to passing emissions and now has no power after 3,500 RPM. I need an experts help. What co...
- 10 replies
Hi All, Will the turbo off an EA-82 turbo engine bolt on a EA-81 turbo engine? Or are they different. I think that my turbo isn't working and I have a complete EA-82 turbo engine in my donor car, but don't want to pull it if they won't interchange as the engine is complete. Thanks Steve
Trying to ID the Carb on my 83 GL 4DR Sedan. I can't find the ID numbers, not sure if it is a Carter or Weber. Need to do a rebuild and looking for the right kit. Thanks.
