Search the Community
Showing results for tags 'ea-82'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 3 results
  1. Hi All, Will the turbo off an EA-82 turbo engine bolt on a EA-81 turbo engine? Or are they different. I think that my turbo isn't working and I have a complete EA-82 turbo engine in my donor car, but don't want to pull it if they won't interchange as the engine is complete. Thanks Steve
  2. Picked up a 90 Loyale SW, 5spd, 4wd earlier this year for a few hundred bucks. Is has 198829 miles and was suffering from the TOD. I drove the car prior to purchase, but only up in to fourth due to the area. Everything worked and it ran just fine. Upon getting the bru home I proceeded to perform the following: Pulled the engine and replaced the front crank seal, rear crank seal, and cam seals. Re-installed the HLA's so that the oil inlet orifice was correctly oriented. Converted the power steering to manual and removed the pump and associated lines. Replaced the timing belts and tensioners; discarded the belt covers. Replaced the oil seal and mickey gasket. New water-pump, cap & rotor, plugs and wires, clutch assembly, EGR Solenoid, Purge Solenoid. Timing set at 20 degrees BTC. Idles +/- 700 rpm No Codes (cleared by replacing the two solenoids mentioned above) It starts and idles, though will backfire through the intake when depressing the accelerator. When engaged into gear, totally bogs down when the clutch is let out normally and will not go. If I gas it up in the rpms and dump the clutch, it burns rubber but only briefly and bogs down. i have checked the TPS; both for measured adjusted and electrically-okay I have measured the Air Valve and MAF and both are coming back in tolerance. What am I missing?
  3. I was encouraged to take care of everything while replacing the timing belts on our newer Subaru, the '89. The metal tube inserted nto the water pump has an O-Ring on it. The condition deems replacement is neccessary. The groove that it resides in is square in nature and the O-Ring is now sporting a rectancular cross-section. ~Is the O-Ring in question just a 25 year old bit of rubber which is now misshapen OR was this O-Ring originally shaped in a NOT-ROUND manner? Thank you, Gentlemen!
