Search the Community
Showing results for tags 'ej conversion'.
For all of those out there contemplating an EJ conversion, this is one of the reasons why buying a donor vehicle can be easier - especially for the first timer. But with that said, this is how I've gone about it twice now - building a conversion from parts of several cars - why? Mainly because I've been given parts from some good mates which only require me to get the main bits like the engine and some supporting pieces that are needed for all conversions. Space constraints of renting can be prohibitive to having a donor vehicle on the property too. So this is how I "bench" test my engine and cutdown loom (plus it's good fun). Loom was cut down last week and the test done this weekend gone. Everything wiring wise checks out. Engine wise I have a code 35 (purge control solenoid valve) and no knocking on start up Now it'll get some preventative maintenance such as head gaskets while it remains out of the vehicle. https://youtu.be/vBXrmIzWiZY I reckon @sparkyboy will wet his pants at this and I kind of hope a few more of you will too (and be inspired to do your own conversions!). I've since fitted a radiator and run it for a longer period of time. I'm hoping to do this again later in the week, not that I have to, but I would like to see the light for the fan trigger to come on... This will end up in my Brumby once both engine and vehicle are ready. Cheers Bennie
- 17 replies
- 1
G'day fellow conversion nuts! I'm after the wire or a "how to" wire up the thermo fans to the ECU of the EJ engine. I've got an '88 L series with an EJ22 installed. I've got the thermo fans running from the stock EA radiator thermo switch. Recently I've been thinking that it would be more beneficial to have the ECU operate the thermo fans rather than letting the radiator potentially get hotter than the ECU wants it to be before the fans kick in. Anyone done this with their conversion(s)? Here's a couple of pics of my ride and conversion: Regards Bennie
- 11 replies
- EJ conversion
- thermo fans
(and 2 more)
Tagged with:
