Search the Community
Showing results for tags 'engine load'.
  • Search By Tags
  • Search By Author
  • Welcome to the USMB!
    • Members Rides
    • Crosstrek "XV"
  • Marketplace
    • Ultimate Subaru Store
    • Products for your Subaru
    • Performance Tech Forums
    • Subaru Modifications
    • Subaru MotorSports
    • Engine
    • Engine Electrical
    • Heating and Cooling systems
    • Body Exterior
    • Interior / Body Electrical
    • Stereo tips and tricks
    • Offroad Modifications
    • Suspension and Steering
  • Off Topic Areas
    • Shop Talk
Product Groups
  • Member Accounts
  • Ultimate Subaru Decals
  • Subaru Parts
    • Weber Carbs and Parts
    • Used Subaru Parts
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Full Real Name
Occupation
Ezboard Name
Referral
Biography
Vehicles
Found 1 result
  1. I recently purchased my second Subaru, and it has some puzzling problems. When I start it up, it revs up to 1,500 - 2,000 rpm for 30 seconds and then drops down to 1,200. The AT Temp light flashes 16 times, and the Check Engine light is on. When I shift the transmission into gear and try to drive, it acts like the engine is under a very heavy load. At first, I thought the exhaust was clogged, but after checking, I don't think it is. As the car accelerates, it shifts very hard, and when I take my foot off the gas, the car slows down as if it had a stuck brake cylinder (but it doesn't). Finally, when I stop and shift to neutral or park, the engine still acts like it is under load. When I shut the engine off, the drivetrain relaxes, and the car rolls backwards a little bit. When I pull the code from the ECU, it tells me there is a problem with the idle air control valve. I took it off and cleaned it. I also tested the resistance on the pins, and they are around 9 ohms like they should be. Could my idle air control valve still be bad? What about this transmission problem? At first, I thought it might be the Duty C solenoid or transfer clutch, but I cannot read an error code from the transmission. I am using an ELM327 code reader.
